I've created a form that works fine on iOS devices (iPhone Plus & iPad) but the relevant "begin group" and "end group" sections are not opening in Android when I select the appropriate answer for the 'trigger' )i.e. 'Yes') see Android_Habitat_Group_Question.
Another individual "relevant" is always open regardless of answer and condition. see Android_Species_Genus_Question
Hi Dudley, thanks for the screenshots. One thing to try is modifying the relevant expression to use selected to specify the answer, for example:
selected(${GotHabitat},'YES')
Please see https://community.esri.com/groups/survey123/blog/2016/05/28/the-art-of-hiding for some useful info on the relevant column. If possible, could you please provide the XLSForm for your survey so I can test the iOS versus Android behaviour? Thanks, Jim
Thanks; I didn’t realize that selected() was used in singles
An upgrade of my Android app has fixed most of the issues I think, but will convert those next publication cycle
Attached is XLXSForm (I hope this is what you want)
Dudley Hartel
Science Delivery/Technology Coordinator
Forest Service
USDA Forest Service
p: 706-410-5568
c: 706-410-5568
dudley.r.hartel@usda.gov<mailto:dudley.r.hartel@usda.gov>
747 Maxine Dr
Baton Rouge, LA 70808
www.fs.fed.us<http://www.fs.fed.us>
<http://usda.gov/>[Forest Service Twitter]<https://twitter.com/forestservice>[USDA Facebook]<https://www.facebook.com/pages/US-Forest-Service/1431984283714112>
Caring for the land and serving people
Sorry for the 2nd reply, but in applying the selected() function, I remembered I also used the following:
$ != 'UNKN' Is there a syntax for selected() that returns the negative case without listing all of the positive? I Googled it, but didn’t get any returns with examples I didn’t try: !selected($,'UNKN') ???
Hi Dudley, thanks for the XLSForm. I am unable to reproduce the issue. The relevant questions work as expected when I open your survey on Android (see attached).
Which version of the Survey123 app are you using? And on which Android device (make, model and Android version)?
Just to clarify, for select_one questions ${GotHabitat}='YES' is correct, although selected() will also work. I thought it might be worth trying the selected() option but my apologies, it was a bit of a red herring! So ${DateSeasonChoice} != 'UNKN' is correct for specifying 'not equal to' on a select_one.
Jim
I suspect that an Android update of Survey123 probably fixed this problem; I’m on 3.1.159 at present
On iOS 3.1.158
Form is working fine for me now
Signed in members can post, follow updates, and more. New here? Register a free account.
