Survey123 form created from existing feature service cannot edit attachmnet
3221
12
11-15-2017 02:07 PM
YuyingLi
I have a feature services that enabled attachment based on the global ID. I created survey123 form based on the feature service and manually included photo repeat in the form. When I tried to publish the form to the existing feature service, I got an error message: the feature service does not match the requirement to edit repeat.
Anything I am missing?
SMauri
Hi James,
any ETA for supporting adding/editing attachments via Inbox? Any idea for a workaround in meantime?
Thank you,
Stefano
JamesTedrick
Esri Esteemed Contributor
Hi Stefano,
Adding attachments is supported for addition-only repeats.  You could possibly construct separate forms for addition and updating as a workaround.  We don't have a firm timeline for supporting this in update repeats.
by Anonymous User
Not applicable
James,
Is there any update on the supporting adding/editing attachments via inbox?   Not understanding the separate form comment and how they would tie together.
I am wondering if it would be possible to invoke a new form and populate the new form with the ID from the inbox based form.      What I am thinking is I am on a record with ID#123 and then invoke a simple form (maybe a web-based Survey123  form) via a button that launches the simple form in a browser via the survey web URL to capture pictures.  When launched into the form the ID#123  is transferred to the new form.   This will enable the attachments (pictures) to be tied back to the original feature service records through a related table.
Maybe this has been asked in another place in the forum...
Thanks in advance for your insight,
Robert
