I have created a survey123 connected to a underlying feature layer with related tables
. An inspection table related to a trees present table. After increasing the number of records returned by an inbox query beyond the default of 2,000 records. iOS running Survey123 version 3.12.277 crashes. Both on iphone & ipad both on 14.6. Similar to this old bug that should have been fixed in version 3.7
BUG-000123911: After increasing the maximum feature count for a fea.. (esri.com).
I also note when you press the Refresh button, the first time nothing happens and you have to press it a couple of times for to start refreshing.
Has anyone else experienced anything similar?
