Survey123 filter & generated report
782
03-21-2023 02:00 PM
RonaldVanderpool
Can someone point me to some guidance for generating a report in S123 that provides the selected feature and its related records for a specific time range?
I can easily filter the data to show it in S123 table, can export the needed data out to Excel, and even generate a report that delivers the feature data plus related data but, even though the table is filtered it still returns all of the related data, not just the filtered results.
I emailed Ismael but do not think he got the email.
Katie_Clark
Hi Ron!
How are you trying to generate the reports? Are you using a custom report template?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
RonaldVanderpool
Yes Katherine,
But I am using the default schema, just with a little custom look and feel.
