Survey123 field app compatibility with Android 10
2610
11-22-2020 08:05 AM
OsamuKumasaka
I am thinking about buying a Samsung - Galaxy Tab A7, which runs Android 10, primarily to conduct a field survey with the Survey123 app. Will it run okay? Are there any known problems with Android compatibility and the desktop app?
Thanks!
Alber_Verster
According to Esri's System Requirement document, all Android versions from 6.0 and later are supported.
System requirements—ArcGIS Survey123 | Documentation
As long as you are on one of the recommended OSs, there should not be any compatibility issues however, if you do encounter any, feel free to contact Esri's Support.
Regards,
Alber
LloydLochridge
Signature field in a Survey 123 survey working on Andriod Tablets ver9 and 11 but; not on TrimbleTDC600_2 with Andriid version 10.  Thoughts/Suggestions?
