Survey123 feature service Table not accessible in Map Viewer layer options
4151
13
05-16-2023 01:28 AM
ChristopherCounsell
MVP Frequent Contributor
Key details:
  • Survey123 Connect 3.17.55
  • Publish new survey form with a point layer and repeat (no geometry in the repeat). Have tested multiple surveys and devices. No keywords or shenanigans.
  • Add created feature layer to Map Viewer
  • Click layer options... no 'table' option for the point layer
  • Click 'show related records' in the item overview data page and it returns 'Data Error'
  • The table appears:
    • In Map Viewer Classic
    • In the Map Viewer pop-up
    • For the related table (no geometry)
    • In a View layer of the same service, in Map Viewer
Is this a known issue? Bit concerning if the new Map Viewer isn't friendly with simple surveys or there's something else going on with the tables created by survey
ChristopherCounsell
Not all bugs are publicly listed. Typically only those that are verified and impact a majority of users are shown on the technical support website.
You should ALWAYS contact ESRI technical support if you are impacted by an issue, even if the bug is known. This lets ESRI assess the numbers of users impacted and let's you get additional information on the defect. Including if and when the issue is fixed.
In believe the issue persists but there is a workaround in edit/visibility settings.
DanielDery
Unable to find this BUG-000158590, but the workaround is to make sure that Editors can see all features is checked in the Hosted Feature Layer Settings:
ChristopherCounsell
Is there no ability to 'show related records' in Map Viewer? What about the new apps like Experience Builder and ArcGIS Dashboards? I know we can show it in the pop-up, but a table/export function is key for us...
DougBrowning
MVP Esteemed Contributor
