Survey123- External Select and a Text field.
1055
01-24-2018 08:05 PM
JyotiRohodia2
Can we configure a text field with External select sheet in such a manner that based on the value we provide in the text field, it will filter the list of choices from External select choice sheet. This is similar to Cascading but instead of using Select question we are using Text field with External select sheet.
JamesTedrick
Esri Esteemed Contributor
Hi Jyoti,
Yes, the choice_filter expression can use the value of a text (or any other) question.  There is a limitation in teh complexity of the filter statement - it will work best with direct match checking.
