If I view the submitted forms in the Survey123 Dashboard/Data tab, the map from the report is not visible in the report view or Print Preview.
Event thou the survey was configured to have a map:
Hi Carl,
I noticed that this morning as well! Doesn't work correctly in IE11, Chrome or Firefox.
I couldn't see anything obvious in Chrome F12 Dev tools either.
Carmel
Carmelce related to your issue, do you have a Detailed Map configured in Survey123 Connect?
eg:
Yes we do, we have it centred off the west coast of Africa - the home button in https://survey123.arcgis.com/ centres around the extent of all the data and not the extent set in Survey123 Connect.
I think that could be part of our problems. I had users, using a different survey where that feature is not configured and the submitted surveys appear normal in the web app.
You're right!
After testing, I've found the following:
I'm going to post here as well to let Zhifang and the team know the function doesn't appear to be working correctly.
