Survey123 Custom Report Font Quirk/Bug?
1909
05-05-2021 08:07 AM
DanAllen
Using the website version of Survey123, I have created a custom word docx report template and uploaded it to the Survey 123 website.  When I created my form, I used Arial Narrow 10pt font.  I then uploaded it to Survey 123.  When I create a word docx report, it comes out exactly like the template I uploaded, and everything is still Arial Narrow 10pt font.
The problem arises when choose the export report to PDF option.  The PDF version appears to substitute Arial Narrow 10 pt font with Calibri 11 pt font.  This makes all the text bigger and completely messes up my form.
Is this some kind of quirk/bug, or did I do something wrong?
Thanks
KayleeRivera
Hello! You could try embedding the Arial Narrow font in your Word Document. This has worked for some other quirky behavior.
KayleeRivera
DanAllen
You are a genius, that worked perfectly to fix the problem.  Thanks!!
