Survey123 crashes after taking image on Android.
2687
12
06-29-2023 12:48 PM
DanielLoegelCMS
Survey123 v3.18 crashes after taking an image on an Android phone. Happening on a pixel 4a and Galaxy 9 phones. The Survey123 was published with 3.11, so updated the form to 3.18 and republished. Still crashes when taking an image. It started at the same time as the latest update to 3.18. The app version on the Android is 3.18.142. Works fine on an iPhone. Not sure if it's a bug or something else going on.
Any ideas?
ZacharySutherby
Hello @DanielLoegelCMS
Would you be able to pass along a diagnostic log when the crash occurs? Are both your Pixel 4a and Galaxy S9 on the same version of Android or different versions?
It would also be helpful to obtain an ADB log from the device to see the OS logs as well. Please feel free to reach out to Esri Technical Support for assistance obtaining this log.
Thank you,
Zach
ZacharySutherby
Hey @DanielLoegelCMS
We are able to reproduce the issue on a couple of our devices as well and are currently investigating the issue. The ADB log would be helpful to verify you're seeing the same issue we are. Please feel free to reach out to Tech Support to obtain the ADB log and log an official BUG for the issue.
Thank you,
Zach
DanielLoegelCMS
A support ticket has been opened, thanks for your help!
Daniel
ChristopherCounsell
MVP Frequent Contributor
Hi @ZacharySutherby  we are seeing this as well. Have a support case. Can you please share the bug number and any updates?
Galaxy Tab Active Pro SM-T545
Android 11
One UI version 3.1
Survey123 field app 3.18.142
Survey123 Connect 3.18.123
Cheers, Chris
ZahraParhizgari1
Hi Daniel
Was this resolved? I started to have the same issue on my Pixel4a a few weeks ago.
Could you please share the solution if there is one?
Thanks
Zahra
ZacharySutherby
Hello @DanielLoegelCMS @ChristopherCounsell @ZahraParhizgari1
This issue has been logged as BUG-000159580. We have identified a fix for the issue and should have more information on when the fix will be released in the next day.
Thank you,
Zach
Dhall
Hi Zach,
I'm having the same issue as well. Any update on this bug?
TaiSubia
Is there an update on this fix? all was working well for me and I was able to  use survey123 to conduct my inspections on June 29. the app auto-updated on June 30.
I made some adjustments to my form to improve functionality, and now it crashes when I try to take a photo. And I need that feature to save me time and labor with writing my inspection reports
I'm using it on a Samsung Galaxy Tab Active Pro (SM-T540) running Android 11
ChristopherCounsell
Thanks @ZacharySutherby . Same as BUG-000159342? What Support gave me
