Survey123 Connect: Select_one question chooses lowest descending string value from 8 other select_one questions.
656
04-09-2020 10:49 PM
MasonPahl1
I have 8 categories (fields) of inspection components: each component has its own defect rating (select_one, A-E).
ratingAA
ratingBB
ratingCC
ratingDD
ratingEE
The structure is usually (but not always ugh) summarized by the worst rating of all of the 8 components (A is best, E is worst). I have created an 'Overall_rating' field, I need it to pick to the lowest alphabetical letter of the 8 separate select_one choices. No idea where to begin. I thought of changing the choice values to integers but not sure if that makes it easier or harder.
Thanks in advance.
DougBrowning
MVP Esteemed Contributor
Little clunky but not too bad.   Do a concat on all the CAV values.  Then a big if statement.  If contains E, E, if contains C, C, etc.  If you just have A-E not so bad.
Hope that helps.
