Survey123 Connect Relevant column
1119
08-15-2024 11:17 AM
BenC_WallaWalla
Hello all,
I am using the latest version of Survey123 Connect (3.20.63) and I'm trying to design a survey with relevant fields that I control to show up only when a previous question's answer allows it to. That functionality works except when I look at the actual survey123 Connect app to test it out there is a blank box before the choice selection is committed to. Like I said, everything works but cosmetically I want to get the box out of there. Below are images of what I am talking about.
Thank you,
Ben
abureaux
MVP Frequent Contributor
You using grid?
If so, swap to dynamic-grid on the settings tab
abureaux
You using grid?
BenC_WallaWalla
Thanks a bunch!
