To create our survey to edit data directly to a feature class in our geodatabae, we have been following the steps How To: Create Survey123 for ArcGIS surveys that connect to non-federated ArcGIS Server services
I recently updated to SurveyConnect 3.11. After publishing the survey in Survey123 Connect, when I open the survey in the Survey123 web application to change some of the settings under "Collaborate" tab we get an error: Item does not exist or is inaccessible.
I'm at a loss of how to fix this. I've added the xls form below.
This is our survey https://survey123.arcgis.com/share/553079f5b265483083910f9f0e11da45
You may find this helpful https://support.esri.com/en/technical-article/000023862
I am also having this issue and was wondering if someone came to a solution yet? Need this data to stay connected to the server for data collection, but cannot get past this to add the correct URL into the web map's point layer.
@JamesTedrick
Sorry Megh, we are still having this issue. Good luck and let me know if you figure out why we get this error!
Signed in members can post, follow updates, and more. New here? Register a free account.
