Survey123 Connect | note type | image | jpg --- won't show in the browser, what am I doing wrong?
1184
05-06-2022 09:51 AM
Survey123Jedi
This is the first time I've needed to use the browser, and I'm sure there is something I need to do, but I don't know where to start. I've checked the community, but when I include the word "image," I get too many results. Thank you so much for your attention and participation.
This is how it should look.
ZacharySutherby
Hello @Survey123Jedi
What's the file extension for the image you are using?
Thank you,
Zach
IsmaelChivite
Esri Notable Contributor
Hi
I bet the name of the file does not match perfectly. Just make sure the name of the file in the media::image column is exactly the same as the file you copied in the survey's media folder
