Survey123 Connect - Hidden value type vs. Hidden appearance type
5169
12-28-2021 02:08 PM
Katie_Clark
MVP Regular Contributor
In both the "Type" and "Appearance" column of Survey123 there is an option for "hidden".
What I'm wondering is, what would be an appropriate use-case for one vs. the other? Why would you ever want a hidden question type rather than a note type with a hidden appearance? Is there a best practice regarding this?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
jcarlson
MVP Alum
I've wondered that as well. According to the S123 docs:
By setting the appearance to hidden, any question type, including groups and repeats can be hidden from view when filling out the survey, but will accept and submit default values and calculations. This is more versatile than the hidden question type, as it can be applied to any question type.
Which more or less confirms what I would have guessed. A hidden type question accepts any input, whereas a hidden date/integer/text question will ensure that any calculated value is applied as the correct data type.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
- Josh Carlson
Kendall County GIS
Katie_Clark
Thanks for the reply, Josh! That's more or less what I had assumed, but wasn't sure if there was some nuance I was missing.
Best,
Katie
jcarlson
MVP Alum
So, a quick test: I have a date question which is used to populate two other questions, one a date w/ hidden appearance, one a hidden type.
When I test submitting it, I can see that the hidden date has the timestamp integer, the hidden type has a string of the integer.
- Josh Carlson
Kendall County GIS
DougBrowning
There is also the body::esri:visible column now.
