Survey123 connect filter domain table issue
887
08-27-2024 12:53 PM
RECEPÖZDOĞAN1
Hi every one,
I need to example of filter to domain list according to another field conditions.
There is a list of many tag numbers available, and I don't want to index the entire list. I need to filter this list by the value in another column.
Let me give you an example, if the value in column A is "2", then I want to see only 1 to 10 in the domain table connected to column B,
or if the value in column A is "2"  I would like to see the labels of the domain list that depend on column B according to its value contains the expression " B02".
Tags (1)
Lei_Liu
Hi RECEPÖZDOĞAN1,
Check out this blog that introduces choice filters in Survey123 and offers some common techniques for working with them effectively. It might be helpful to you:  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Lei
Lei_Liu
Hi RECEPÖZDOĞAN1,
Lei
RECEPÖZDOĞAN1
Dear Lei,
Thank you answer to my topic.
it was helpful for my task.
I got and applied several example to my form.
I had to manage over 18000 ID numbers for inspection studies.
when I wrote these numbers on the XLS form, I observed that the system was in a very heavy state of operation. Then I defined the link from inside survey connect by uploading cvs file to our portal. I defined the classifications by adding sub-milks, such as in the example you sent me in csv file, it worked perfectly. You can find the example of csv file in the image.
 Thank you.
Recep
