Survey123 Connect failing to republish survey
847
05-12-2020 01:39 AM
Jeff_VanEtten
I am attempting to republish a survey that I published recently.  This is using the same version of Connect (3.9.120).  I had to make a few changes, which resulted in two new fields being added:
When I go to publish I get this screen, which I have seen before.
Options screen:
Publish survey:
Once clicking on publish, the Publishing process is stuck on this screen indefinitely. I have to click on the X to close this after waiting for several hours.
I have captured the process using a log file.  Please let me know if you want me to upload this here.  I have attempted all of the following so far:
Close connect and retry.
Reboot computer
Removing any views (stakeholder) from AGOL.
Options I cannot do:
I cannot publish a new survey, as there is exisitng data in this survey currently with our surveyors collecting new data as we speak.
Jeff Van Etten
Head of GIS
Tetra Tech Ltd
SMauri
Occasional Contributor III
Hi Jeff,
try to add this two fields manually from ArcGIS Online UI and retry to publish your Survey...
Cheers
Stefano
SMauri
Hi Jeff,
Cheers
Stefano
Jeff_VanEtten
Stefano
Many thanks for this.  I was able to publish the survey once this was added manually.  Looks like this is not so seemless right now for publishing new updates!
Regards
Jeff
Jeff Van Etten
Head of GIS
Tetra Tech Ltd
SMauri
Pollice all
