Hello everyone,
Unfortunately, my research on dynamic filters in repeats did not result in what I was looking for, so I'll try it here
The idea is to open a survey in edit mode. You could do this with an activated inbox.
If I now open a submission, the form consists of a drop-down menu with the values A, B and C and a repeat section, where the values A, B and C can also be entered in a field. Assuming there are 100 entries in the repeats section. 30 of them are entered with A, 70 with B and 0 with the value C. Based on the selection in the drop-down menu outside the repeat, I now want to filter the repeats so that I don't see all 100. Is this possible?
I've read that you can limit repeats using the query parameter in Esri::Binds::Parameters, but I haven't managed to do it dynamically yet. Is this even possible?
Any hints are appreciated.
Best regards
Sven
