Survey123 Connect default file location
1969
02-02-2022 10:06 AM
ahargreaves_FW
Hello
is it possible change the file location that Survey123 Connect uses from C:\Users\MyName\ArcGIS\My Survey Designs\MySurvey to something else?
Tags (1)
Katie_Clark
MVP Regular Contributor
Oh, how I wish this was the case.....however, with the way the software is currently set up, this isn't possible.
Many people have requested this capability. Please upvote this idea to help it get more attention!
https://community.esri.com/t5/arcgis-survey123-ideas/survey123-ability-to-have-survey-stored-on-a/id...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
