Survey123 Connect Crashing When Opening Survey
2275
9
11-17-2017 01:16 PM
JohnWalls3
New Contributor II
I have multiple surveys, but one survey in particular will not open in Survey123 Connect. I noticed that it only happens when I'm updating the .xlsx form. But if I open the survey in connect without agreeing to the refresh, it opens with no problem. I've gone through the rest of the forum and tried other solutions without any luck. I am using 2.4.60 version running in Windows 7. Is there another solution I should be looking for?
Thank you for any assistance.
by Anonymous User
Not applicable
Hi John,
Could you please share a copy of your survey (.xlsx file) that crashes Connect so I can take a closer look.
Regards,
Phil.
JohnWalls3
New Contributor II
Good morning Philip,
I have attached the .xlsx file when you have a chance to take a look. Thank you!
JamesTedrick
Esri Esteemed Contributor
Hi John,
I'm not seeing the xlsx file attached to this message- I just wanted to check before Thanksgiving timing took hold (Philip may not be able to respond before you're off work).
JohnWalls3
New Contributor II
Hi James, I attached it to the original post.
MichaelKelly
Occasional Contributor III
Hi John - one problem that jumps out at me is the Scientific_Name choices list. The associated names field contains spaces and full stops while it should only contain alphanumeric characters. This may be resulting in the unusual behaviour you are experiencing.
JohnWalls3
New Contributor II
Hi Michael,
I had originally thought it was an issue with the list name since the problem arrived after I implemented it. However, once I removed it and tried it again the issue still persisted. But moving forward for any other projects, I'll certainly keep those recommendations in mind when formatting. Thanks!
JohnathanHasthorpe
Hi John
We have done some investigation into the issue and have found it to be a bug (and not a configuration issue your end).
We will update GeoNet with further developments.
Thanks
John
JohnWalls3
New Contributor II
Hi John,
Do you have a timeline when that will be fixed? Approximately?
JohnathanHasthorpe
Hi John
This issue has been resolved at 2.7. Please verify your end when 2.7 is released later in the month.
Thanks
John
