Survey123 connect Calculating Geopoint from Pull data need to AutoPopulate
659
09-02-2021 08:09 AM
NeelimaBalivada
i am getting lat and long values, from that how to pull the data and zoom to map automatically need to populate, when select one field
by Anonymous User
Not applicable
Hi @NeelimaBalivada,
Are you askig how to use pulldata() to get the zoom of the map? This is not possible, the following data can be extracted from a geopoint using pulldata(), but these all relate to data provided by the location service, not the map:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/geopoints.htm#ESRI_SECTION1_0C78C5A67E824...
Or is your question about how to calculate and set the geopoint, from lat/long and other data you have alread in the survey, and then use a calculation to apply it to the geopoint question?
Regards,
Phil.
