Survey123: Can I remove the address lookup box from the geopoint locator?
1118
04-09-2019 12:20 PM
MikeSlattery
I have a simple Survey123 form with a geopoint that I made using the GUI.   When I click 'Set Location', I get an address lookup box within the map locator field.   I am using the locator to select a geopoint in an open park setting, so the address field isn't needed.
  1. Is there a config setting to remove the address lookup box?
    (I'll try XLSForm if necessary but I couldn't find a setting there either.)
  2. Does the address lookup field in the survey123 geopoint locator field use up credits?
    I really don't want that!
Thanks in advance for any clues...
JamesTedrick
Esri Esteemed Contributor
Hi Mike,
There currently isn't an option to remove the address search field.  The address lookups count as geosearch (the non-credit consuming) as the user still has the opportunity to change the location before storing the data.
MikeSlattery
Thank you for responding to both questions!
