Survey123: calculation based on a old value in the database
986
06-16-2020 02:43 AM
PanGIS
Hi guys,
I am trying to create a small form that make easy the collection of values and makes the calculation on its own:
(I am using Connect)
Here is the case:
on the  20/03 I have a total =  64
on the 21/03 I input New = 9
so the calculation takes the total of yesterday and add 9+64=73
(on the other way round if I need to subtract a value from the one of yesterday)
Is there a way I can get  "case  total" = 73 without checking the old value in the table and make the addition manually?
Thanks!
DougBrowning
MVP Esteemed Contributor
Are you trying to pull the value from an old form?  Or is this in a repeat?  In the web map?
If you are looking across form then Arcade in a web map would be a way to go.
Hope that helps.
