Hello all,
I just upgraded from 3.11something to 3.12.232. The select_one question whose choices have County name for the label and the 3 digit fips for the name (ex. 001). It worked fine previously by storing the '001' value. After the update, the question now seems to view the text value as a number. I concatenate with state fips in a hidden field. I changed the hidden to note and see it happening in the form UI upon selection of the County. And yes, I cast the values as string in the calculation. 🙂 Anyone else seeing this issue and or have a suggested work around?
Select one - County name with 3 digit FIPS:
| County | 001 | Adams |
| County | 003 | Allegheny |
| County | 005 | Armstrong |
Selected value save "1" instead of "001". Select one field type is esriFieldTypeString.
Example attached.
Jim
*****UPDATE*****
I engaged tech support. This is a recent bug #BUG-000138199.
Suggestions for workarounds short of post-submission scripting would be much appreciated. Thanks!
