I have a published survey in which several fields are primarily numeric inputs, but will occasionally require another character. Since the primary input are numbers I set the appearance of these questions to 'numbers' so they could type most of the filed with the pop-up numb pad (as typing in long number strings with the IOS keyboard is tedious). In the previous versions of the IOS app a field is set to have the 'numbers' appearance would still have the IOS keyboard pop up so they could use it to type in the other characters, but with this latest release the keyboard no longer pops up and you also don't seem to be able to copy or paste into the field.
Is there a way to have the number pad appear but also allow input from the IOS keyboard?
