Survey123 3.24.21 Crashes When Taking Photo on iPhone 17 Pro Max (iOS 26.0)
914
11
09-24-2025 05:40 PM
CameronRex1
Hi all,
I'm experiencing a consistent crash when attempting to take photos in Survey123 version 3.24.21 on an iPhone 17 Pro Max. I’ve done extensive testing across multiple devices and OS versions, and the issue appears to be specific to this hardware.
Issue Summary
  • When I try to capture a photo using the camera inside Survey123, the app crashes immediately.
  • This happens before the camera fully loads.
  • The crash is repeatable across multiple surveys.
Working Test Devices
Device iOS Version Survey123 Version(s) Result
iPhone 16 Pro Max26.0 (Beta)3.24.21Works
iPad Mini (A17 Pro, MYHC3LL/A)18.6 (22G86)3.23.36 / 3.24.21Works
iPad Mini (same)18.7 (22H20)3.24.21Works
iPad Mini (same)iPadOS 26.0 (23A341)3.24.21Works
Failing Device
Device iOS Version Survey123 Version Result
iPhone 17 Pro Max (MFXQ4LL/A)26.0 (23A345)3.24.21Crashes on camera launch
Other Notes
  • Attaching a photo from the library works fine — only in-app camera capture causes the crash.
  • Happens even in very simple surveys (e.g., one image question, no repeats or logic) and complex ones.
  • Appears to be hardware-specific (iPhone 17 Pro Max) rather than OS-specific.
Questions
  1. Has this issue been reported by other iPhone 17 Pro Max users?
  2. Is Esri aware of compatibility problems with iOS 26.0 or the new camera hardware?
JohnathanHasthorpe
Hi Everyone
We have found that upgrading to iOS 26.1 Beta resolves the issue for the iPhone 17 Pro Max (the crash no longer occurs when taking a photo). This means that the fix will be dependent on the release of iOS 26.1.
In the mean time see: https://beta.apple.com/ if you are willing/able to test the iOS beta.
John
JohnathanHasthorpe
Hi Everyone,
We are planning to release a hotfix that should address the camera crash issue for iPhone 17 Pro users. We have shared the test build on the Early Adopter Community: Link here . The build number is 3.25.11.
Please test it out and let us know if this works for you.
Thank you.
