Survey only loads on reload.
282
09-08-2025 11:33 AM
TL2
After I save my excel in S123 Connect my survey will load a blank page.  I must always press Reload Survey.  The same thing happens in Survey123, it will first load a blank screen, then I have to go back out and tap Collect a second time for the survey to load.  Any ideas?
ZenMasterZeke
I've seen it load a blank screen when you're using a grid style, fixed or dynamic, and have a generated_note field in the survey. Don't know whether that's the issue here or not.
See this post.
