Survey disappears from inbox after editing.
605
11-24-2017 09:26 AM
TonyGroeneveld2
Not sure if this is by design or I'm doing something wrong.
I have a survey that uses the inbox feature. I click on a survey in the inbox, make some changes and submit it. The application returns me to the inbox but the survey that I just edited disappears. If I hit Refresh it comes back.
Tags (1)
IsmaelChivite
Esri Notable Contributor
Hi Tony. This behavior is expected. Once you open and submit a survey from your Inbox, it disappears from it.   If you refresh the Inbox, it will fetch all corresponding features from your feature service and populate the Inbox again.  More information about the Inbox can be found here: http://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm
IsmaelChivite
