Survey Data not showing up in report exports
504
06-17-2021 05:45 AM
mattkramer
Hello,  I have some survey data that has been collected and am trying to generate some reports from this data.  I have made my template and everything seems to be working except for a couple data fields which are not transferring from the table to the report.  Here are some screenshots for context.
Similar to the second screenshot, the "MeterID" field does not transfer to the report that is generated.
That field is a select_one_from_file field if that is important.
Thank you!
JodyZhengLiu
Hi @mattkramer
Select_one_from_file is not supported in the report for now and it will be supported in the next release planned in September.
Jody
JodyZhengLiu
Hi @mattkramer
Jody
mattkramer
Thank you for letting me know, I will be on the lookout for that!
