Survey 123 Webform not auto-populating geolocation from CSV.
1671
7
09-10-2019 07:11 AM
RVG296
I am trying to pull data from a CSV which has the lat long values for 4-5 cities and make the map automatically update when we select the cities. This is totally working fine in Survey123 Field and Connect, but the web version is not working. I used the right syntax for pulling lat lons in two different calculate types. I also made sure the data sources are correct. But still, I am confused why this error happens only in the webforms. When I look into the chrome developer console, I get this.
Attached is the xlsx file and CSV file.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Rohit,
It appears there is an issue in value conversion of your 'location' question.  Forcing it to be a string by setting the bind::type field appears to address the issue.
RVG296
But I do not want {location} to appear in the survey. Thats the reason I have to use null. I also used the same process as per this esri tech support doc for setting up the location.
Error: Initialing Form... Failed to load data from (data source)
I think this was happening because I am using a calculated field to get the username (property('username'))in field type hidden But if I changed that type to Username and did the same thing, the webform worked fine. Not sure if that was the issue.
JamesTedrick
Hi Rohit,
You can still have the bind::Esri:fieldType column remain null- I was referring to the bind::type column (these are separate, if somewhat closely named, properties).
RVG296
Should I be changing that to String for {location}
JamesTedrick
Yes, set the bind::type column to 'string' for the 'location' question.
RVG296
I just changed that to String and checked my webform but still it is throwing up the same error.
RVG296
James Tedrick
Thank you James.
Once I removed the property('username') in the calculation, the survey worked fine on the Web too.
Not sure if that is the main issue behind this.
