Survey 123 Report Template Error: Failed to parse/does not exist or cannot be found in current parsing scope.
22802
47
03-01-2019 03:47 PM
ChrisShuck
New Contributor III
I am trying to upload a report template to Survey123 however I keep getting the error  Failed to parse "${MT_Amount1} Field "${MT_Amount1}" does not exist or cannot be found in current parsing scope.
I have checked the XLS spreadsheet in Connect to make sure that the tag matched exactly, and to my knowledge the opening and closing tags for the repeat is placed correctly as well
Is there an update that could be causing this? It was working fine a few weeks ago with the same tags and the same survey.
LizRobertson
Thank you for the suggestion.  I cleared browser cache, no change.
I made a copy of the survey; same issue occurred.  So I tried deleting that question that was triggering the "error" and when tried saving/previewing/publishing it displayed the same error message, this time pointing to a different question, which also has not been edited/changed in anyway since last editing/publishing successfully.  Any other recommendations?  Is this just a bug?
Thank you very much for your time.
Liz
ZhifangWang
Hi Liz,
Seems your issue is similar to the BUG-000125687. Can you please upload a screenshot of the modify schema dialog (Publish->Modify schema) which scrolls to the question "Funder"? This helps us to confirm if it's the same issue with the above bug.
Although we fixed the bug and will auto-truncate names for any choice which is longer than 32 characters, there is a chance that a longer than 32 character name is input manually in the modify schema dialog. In this way, we won't change it until you manually fix it.
Zhifang
LizRobertson
The problem is the error prevents me from viewing/modifying the schema, because when I click publish the error message pops up.
Would a copy of the previously downloaded spreadsheet of the data work provide you with the information needed to determine the bug?
ZhifangWang
Hi Liz,
It will be great if you can send me a zip package that contains all files in the survey folder downloaded via Survey123 Connect, which includes the raw "form.json" authored from the Survey123 website.
Zhifang
MichelleWilliams1
Occasional Contributor III
I got his error this morning, has something changed online in the last two days?
RobinGoulette
New Contributor III
I'm having the same problem but with the ${select_one | selected:"yes"}Yes format. Started for me yesterday.
Ruth_JiatengXu
Hi Michelle and Robin,
Does the template work before Jan 29 or 30? If it is possible could you please provide us more information related to your issue? For example, a copy of your xlsx form and report template would help us to reproduce the issue. If you are not able to share these files, could you tell us more about the condition?
Thanks a lot!
Jiateng
MichelleWilliams1
It did work two days before.
I rebuilt the Word document and it's working again.
Ruth_JiatengXu
Hi Michelle,
Good to hear it works. We will keep eyes on the issue you mentioned. If you encounter the issue again, feel free to leave us a comment.
Jiateng
ryanEvanczyk
Hi Jiateng,
I cannot seem to get the syntax correct for a nested repeat in my feature report. The schema is Event_log_X_Incident_Form(mainLayer) > incident_form(repeat1) > patient_signature(repeat2)>pt_accept_refuse(fieldname). Both the main layer and repeat1 are feature layers in the schema.
${#incident_form}
${#patient_signature}
${pt_accept_refuseInpatient_signature},${incident_form.pt_accept_refuse},${Event_Log_X_Incident_Form.pt_accept_refuse}
${/patient_signature}
${/incident_form}
I tried to follow the example above and it returns the error failed to parse ${patient_signature}.
Thanks for your help,
RyanE
