Hello Survey123 users hope everyone is good:
I have been trying to clarify thru documentation if a behavior is possible or not, or if it was in the past:
Customer has Survey123 published against a REFERENCED feature layer (from Oracle DB), the survey works as it should, however, they notify us that at some point, after their Enterprise was upgraded to 10.9.1 from 10.8.1 they are not able to export the data from the Survey123 Data Tab when they administer the Survey.
I checked in our Enterprise 10.9.1 and what it does is the same as in theirs, (the export button goes on loop forever, however it does create an element in portal with the format that you chose to export, but if you download the element and open it in the computer it shows an error that the format is incorrect.
The only difference I saw in our 10.8.1 Enterprise is that it finishes the exporting and the downloading completes too in the browser, but again the, the resulting format is null.
Only thing I have is documentation that indicates that you cannot export from ArcGIS Server Feature Layer (referenced FL):
https://enterprise.arcgis.com/en/portal/latest/use/feature-layers.htm#ESRI_SECTION2_D41B1ACAD7AF4F89881995560453C39B
But still I am not sure if that functionality should work in Survey123 or if it used to work ?
Any help is appreciated.
