Survey 123 Outbox
1495
06-07-2024 10:20 AM
MeganWheatley
Hi All,
I have created a survey in Survey 123 web not Survey 123 Connect. I got notification the end user that the outbox comes out with the data schema and is not direct. Picture attached, any tips on how to fix this? Have not dealt with this issue much before. Would love some good resources to help me come up with a resolution to this.
They are looking for a cleaner version for outbox for example displaying only trail name and trail number. Suggestions welcomed!
I haven't found anything helpful yet at this point. Will continue to browse.
Thank you in advance!
DougBrowning
MVP Esteemed Contributor
Did you set an instance_name on the setting tab in the excel?
MeganWheatley
Hi @DougBrowning ,
I am using the survey 123 web designer for this one. So are you referring to me opening this in survey 123 connect?
DougBrowning
This post is old but it looks like maybe web designer cannot do it  https://community.esri.com/t5/arcgis-survey123-questions/survey123-web-designer-instance-name/td-p/1...
Sorry I do not use web much.
abureaux
MVP Frequent Contributor
I'd say the issue is web designer. If you are making a survey for the Field App, definitely use Connect.
Honestly, I'd use Connect even if making a survey for the web...
