I created my own first survey from scratch to learn a little more. I notice a few issues and I can not figure out what is wrong.
Images - In testing the images on selection choices I added a separate jpg image for each option. In Connect everything looks fine but once it is published and I look at it on my IPad some of the choices show an image while others do not. I'm not really sure why, they are all jpg and all are about the same size? Those bold, underlined below are the ones that do not show on the IPad
| hardwaretype | Guardrail | Guardrail | rail.jpg |
| hardwaretype | LampPost | Lamp Post | Street_lamp_post.jpg |
| hardwaretype | StopLight | Stop Light | TrafficLight.jpg |
| hardwaretype | Siren | Siren | Siren.jpg |
| hardwaretype | Sign | Street Sign | sign.jpg |
| SignType | Stop | Stop Sign | stop.jpg |
| SignType | Road | Road Sign | street.jpg |
| SignType | Yield | Yield Sign | yield.jpg |
| SignType | WrongWay | Wrong Way Sign | one.jpg |
Feature Service - Ok this one is confusing too. I created all the items below and published them. Everything shows up to be collected and submits without any issues. When I goto AGO or the survey123 site to review my results the survey data only shows the geopoint and user data below. Why does the feature class not have all of the items in the survey?
Fields set up
| type | name | label |
| note | Into | This survey is an example of the capabilities of Survery 123. It is a example demo for hardware inspections. |
| begin repeat | InspectRepeat |
| start | StartDateTime | Date |
| username | Username | Name |
| barcode | barcode | Scan Barcode if available. |
| select_one hardwaretype | Hardware | Select the type of hardware being inspected. |
| select_one SignType | signtype | Select the type of sign being inspected. |
| select_one yes_no | Damage | Is there any visible damage to the hardware? |
| image | photo | Take a photo of the hardware |
| video | video | Video all damage to hardware |
| audio | audio | Record the Siren sound |
| geopoint | Location | Select the hardware location. |
| end repeat | InspectRepeat |
Fields shown as collected after submission
| objectid | GlobalID | CreationDate | Creator | EditDate | Editor | x | y |
