Hello All,
Earlier today, I went in to make a change to one of my surveys and I noticed that nearly half the questions were missing in designer. At the bottom, there is a blank question, which appears to be out of order (see attachment). I can't delete this question or post any changes to the survey.
Has this happened to any of you before? I just wanted to check before having to rebuild this survey from scratch.
Thank you!
Hi Austin,
That sounds very strange, I've not seen that before. Have you tried using the 'Save As' option from the Gallery page of the website? Even if that just makes a copy of the corrupted survey, at least you'll regain half of the questions (the ones that aren't missing) and will likely be able to continue to edit.
Hope this helps,
Brett
