Trying to average multiple numeric inputs on a Survey 123 form.
Sorry, try
(${first_field} + ${second_field}+ ${third_field}) div 3
Hi Pete,
You can do this only if you're using Survey123 Connect (not the web version).
1. Create another row for your summary record, for example 'summary_field'.
2. Insert your equation in the calculation field of 'summary_field'. For example, to calculate the average of three other fields:
For more examples and operators see:
Formulas—Survey123 for ArcGIS | Documentation
Hope this helps,
Uri
Hi, i keep getting this message when trying to update the form. Tried the field to calculate as 'calculate' or 'decimal' neither worked. the formula is in the 'calculation' field as written. am i missing something? thanks
Thanks! that did it!
Signed in members can post, follow updates, and more. New here? Register a free account.
