Survey 123: How can I autocreate a geopoint location on a map based on a selected item from a list?
737
09-01-2021 08:27 AM
3CDCOrganizationalAccount
How can I autocreate a geopoint location on a map based on a selected item from a list (i.e. the name of a business) in Survey 123?
Tags (1)
jcarlson
MVP Esteemed Contributor
This is quite possible, and is demonstrated in this S123 blog post. As that post notes, you can use pulldata() along with a CSV of businesses, lat/lon values, then use the calculation concat(number(${lat_field}), ' ', number(${lon_field})) for your geopoint.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
