Survey 123 form fails to publish
1477
10-16-2019 06:45 PM
YuliaMamonova
I get an error (service definition creation failure) with the form attached.
I am sure it has something to do with my 2 geopoint questions that are set as "null" fields, and then lat and long calc is based on those questions.
I need starting and ending time and location of the survey. And I need to capture time/location exactly when the form is first opened and submitted and they should be read-only.
I found several approaches in geonet:
1) Repeats (I never use repeats in my surveys, cause I don't like related tables complications)
2) Multiple geopoints set as null
3) Pictures when they start the survey and then right before submitting.
So I tried 2nd approach, but apparently I did something wrong.
Can you please tell me what approach would be best for my workflow?
Thank you!
Jim-Moore
Hi Yulia
Thanks for providing your XLSForm. It appears the publishing error is caused by a duplicate question name - there are two text questions named "truckdetails". If I rename one of these questions so that they're unique, the survey publishes as expected. Please let me know if this works for you.
Best,
Jim
Jim-Moore
Hi Yulia
Best,
Jim
YuliaMamonova
Jim,
Thank you for your response.
This was exactly what prevented my form from publishing, but as I expected the location is not captured the way it is supposed to. What is the best way to capture ending location and make it static and read-only? So user cannot change ending location. Starting location will be captured automatically.
Thank you!
Jim-Moore
Hi Yulia
Good to hear we identified the cause of the error. Regarding your query about capturing start/end locations, I see this has been discussed in your separate post: https://community.esri.com/message/888133-re-capturing-location-several-times-in-survey123-form
Thanks to James Tedrick‌ and Doug Browning‌ for their replies!
Best,
Jim
