Survey 123 - Converting XLS Forms offline
1925
6
07-26-2017 01:50 AM
Jean-YvesLandry1
Is there a possibility to convert xls forms offline?
2 Solutions
IsmaelChivite
Esri Notable Contributor
Hi, I think Jean-Yves means to use Connect while disconnected from the network.  If that is the case, the answer is no...not yet.  Survey123 Connect uses a web service to validate changes you make in your XLSFile.This web service  is part of the  Survey123 REST API, which is undocumented at the moment, but present every time you use Survey123.  We are working on a setup for this REST API so people can install it locally. We will make the setup available through our Early Adopter Program shortly.   If you were to install this REST API in your own computer (your laptop for example), you could build XLSForms even when disconnected.
by Anonymous User
Not applicable
Hi @DawnDoty,
Yes, the Survey123 website and API can now be installed locally, using the Survey123 local website installer. Please refer to:
https://community.esri.com/t5/arcgis-survey123-blog/arcgis-survey123-website-installer-what-s-new/ba...
We have also added some new beta features to Connect in the 3.14 beta builds on EAC, where you can now specify the pyxform API and use local python tools, mostly for custom annotation palettes, but can be used for offline workflows also. Please refer to:
https://earlyadopter.esri.com/project/article/item.html?cap=e69ef91f45744b98882c651f7b518eb7&arttype...
Regards,
Phil.
by Anonymous User
Not applicable
Hi Jean-Yves,
What do you mean by "convert xls forms offline", could you explain this workflow and requirement in more detail?
Regards,
Phil.
IsmaelChivite
Jean-YvesLandry1
Is this now available?
JamesTedrick
Esri Esteemed Contributor
Hi Jean-Yves,
An initial (very early beta) version of the on-premises installer is available via the Esri Early Adopter Program.  It requires some familiarity with container technology (vagrant, virtualbox).
DawnDoty
How about now?
by Anonymous User
Not applicable
Hi @DawnDoty,
Regards,
Phil.
