survey 123 connect integer function
1025
04-06-2022 07:56 AM
AbulBasharPolas
I have created and published a survey with survey123 connect. I put questions related to age and income but unfortunately after sending the survey I do not see any information regarding age, or income in my output data. So shortly I can say that I do not find answers related to numerical questions when I go to analyze my data
But all other information is there like name, profession, etc,
Please let me know the solution.
Many thanks.
ChristopherCounsell
MVP Frequent Contributor
Can you please provide the XLSForm so that the community can better assist?
AbulBasharPolas
Thanks for your reply, I attached the xlsform and analysis photo here. So I collect data but when I go to analyze and data function, I don't see any output related to integer types of question e.g. age, income.
Thanks.
ChristopherCounsell
Thanks.
The Numbers appearance is not supported in the Web App. I wonder if it is trying to render the form in the web app but it fails.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm
Does the field exist in the feature service?
If you publish a new survey without the appearance set to Numbers, fill a survey, does it work as expected?
Also would recommend sharing the full .xlsx form if you can when posting questions. Really helps. And survey version.
Cheers
