Survey 123 and Related Tables
624
04-29-2021 04:35 PM
Lexicon1950
I have a point layer and a related table for Inspections at those points. The point layer and related table have a relationship that was created in ArcMap and then published online.
Everything is working great with passing information from the point to the form as well as connecting the form to the point in the related tables in the map. However, I noticed that every time a form is submitted a new point is created.
Is there a way to ensure that the survey data is the only data being created for each inspection and each inspection is related to the ORIGINAL point , not created and related to a brand new point?
ZacharySutherby
Hello @Lexicon1950
Assuming you want your survey to only submit to the related table this Esri Support KB article will help you configure your survey to only point to the related table instead of the feature service.
Thank you,
Zach
Thank you,
Zach
