Survey 123 and Hosted feature layer
1072
11-16-2021 09:35 PM
TobyStewart2
I have been following a video of working with hosted feature layers from captured survey data.
https://www.youtube.com/watch?v=E5tW7YIniNo
I created the survey and have added a hidden field called status that when saved should like in the video create a field that is "no" to Null values and has a default entry.
I am unable to replicate this, once the Feature layer is created it is always "yes" to Null values and the default value doesn't appear?
I can create the field post Feature layer creation but my understanding is that this wont transfer across into the Stakeholder or Fieldworker feature layers?
Displaying data collected from the public, like with surveys and interviews, is easy and accurate with ArcGIS Online hosted feature layers. In this session, learn about using hosted feature layer views to expose public information to the public while keeping private information like names and ...
by Anonymous User
Not applicable
Hi @TobyStewart2,
Did you create the survey with Connect or web designer? And where/how did you create the additional hidden field?
Regards,
Phil.
TobyStewart2
Thanks @Anonymous User
I created the survey in Connect and have created the hidden “status” field in the xls connect sheet.
by Anonymous User
Not applicable
Hi @TobyStewart2,
Using the hidden question type in Survey123 XLSForm or using the hidden appearance, just creates a normal text field with same default as a non-hidden text field. It does not change the null values or default entry. In this case the hidden is just applied to Survey123 and when the form is displayed in the field app or web app.
Regards,
Phil.
DougBrowning
MVP Esteemed Contributor
Do you mean the settings on the feature service?  123 does not use the Null values allowed thing like Field Maps does.  It takes care of required in the form.  It does not use default value in the service also.  All in the form.
