Summary Section, Where doesn't work with Query to Field, Get "cannot be found in the current parsing scope"
234
a week ago
Carrie2025
Hello - I am putting together a report where I am trying to pull a list of all previous inspections in a summary report.  the inspections table is linked as a related table using a GUID Field (In my report, called PERM_ID).  From what I read, this should be possible.  However, I keep getting a "Cannot be found in current parsing scope" error.  I know the "PERM_ID" field is correct, it works in other places, as well as in the summary section when not used in as part of the where clause.
It works if I hardcode the value in in - it works if I don't use a where statement, and according to documentation, It should work.
I'm not sure what I'm missing - I've uploaded the report I'm using (Its currently missing the !important to pull all matching value)
Neal_t_k
MVP Regular Contributor
This might be worth a shot, not sure if it will work in the sql.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-repeats.htm
${#PermitInspections_test|where: "PERM_ID ='${<mainlayername>.PERM_ID}'"}
or
${#PermitInspections_test|where: "PERM_ID ='"+${<mainlayername>.PERM_ID}+"'"}
VenkataKondepati
This is a report parsing-scope issue, not a bad field.
In Survey123 reports, the where: clause on a related table runs in the child table’s scope, so the parent field (PERM_ID) isn’t automatically visible. That’s why it works when hardcoded but fails when referenced.
Fix: reference the parent explicitly (or assign it first):
${Inspections | where:"perm_id='${@parent.PERM_ID}'"}
(or assign PERM_ID to a variable and use that).
Related-table queries can’t “see” parent fields unless you explicitly pass them into scope.
Regards,
Venkat
Neal_t_k
or
Carrie2025
Hello There! Thank you so much for your help - I ended up using partially @Neal_t_k solution, but @VenkataKondepati pointed me in the correct direction and gave me the piece that I was missing.  I ultimately went with this:  ${#PermitInspections_test| where:"PERM_ID = '"+$mainlayer.PERM_ID+"' !important" |orderByFields: “OBJECTID DESC”}, inside a table, and it works.  Now, I just need to wait on my user to tell me exactly what he wants in this report!   Thank you so much for your help!
VenkataKondepati
Thanks for the comments @Carrie2025 . I am glad it worked out.
Regards,
Venkat
