Submitting a survey collected offline
1326
06-05-2023 08:05 AM
BruceGodfrey
When collecting data through the app while offline, will field users need to manually push a submit button after reaching wifi or cell service, or can/will the app send it automatically once a connection is available?
Katie_Clark
MVP Regular Contributor
As far as I know, they'll need to go in and hit submit since the surveys will be saved in the outbox.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
BruceGodfrey
Found documentation at the following link - manually push "Send":
https://doc.arcgis.com/en/survey123/desktop/get-answers/submitsurveyresults.htm
