Submission Failure and Duplicate Records
5298
13
11-05-2017 03:52 PM
PeterTimmers
We've had a number of people have the situation where they have gone to submit surveys and S123 says it has failed, they submit again, then we find duplicate records in the feature layer.
We have a feature service hosted on AWS servers and registered on AGOL.
It's not repeatable and I haven't had it happen on any of my tests, but we've had a number of people in different areas had it happen.
We currently rely on a scheduled task to look for duplicates (using S123's unique id field).
It may have to do with photo size and internet connectivity and we've reduced our photo size to reduce the risk.
Has anyone else experienced this?
by Anonymous User
Not applicable
Hi @Fernando_LuisRodríguez_Valle,
Does this happen for all surveys, or just one? Are you using the Inbox and editing existing records, or creating new records? Do all records submitted get duplicated or just some?
Do the surveys have attachments?
Regards,
Phil.
Hi Philip
For the moment it is a general problem that happens intermittently (sometimes yes and sometimes not)
Come about editing existing records and creating new records
Only record with a Submission Failure
Yes we have a attachments (photographics) and unstable connection sometimes
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Logging started: 2021-11-08T13:48:54
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Application Name: ArcGISSurvey123
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Application Version: 3.13.234
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Application File Path: /private/var/containers/Bundle/Application/FF8B1433-4D0C-4040-A431-A0FF3DB0D48C/AppStudioApp.app/AppStudioApp
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Application Directory Path: /private/var/containers/Bundle/Application/FF8B1433-4D0C-4040-A431-A0FF3DB0D48C/AppStudioApp.app
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ AppFramework Version: 5.1.80
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Qt Version: 5.15.2
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Operating System: iOS 15.1
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Operating System Type: ios
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Operating System Version: 15.1
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Kernel Type: darwin
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Kernel Version: 21.1.0
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Build ABI: arm64-little_endian-lp64
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Current CPU Architecture: arm64
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Build CPU Architecture: arm64
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ SSL Library Version: Secure Transport, iOS 15.1
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Host name: Diego
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Domain name:
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Default locale: es_GT
<14>1 2021-11-08T19:48:54Z Diego ArcGISSurvey123 16492 - - $ Release Type: store
<12>1 2021-11-08T19:49:02Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default"] stale focus object AppSwitch_QMLTYPE_411(0x2810c5550) , doing manual update
<15>1 2021-11-08T19:49:36Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 2
<15>1 2021-11-08T19:49:37Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 0
<15>1 2021-11-08T19:49:54Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 2
<15>1 2021-11-08T19:49:55Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 4
<15>1 2021-11-08T19:49:55Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="903"] Portal: Token expiry timer disabled
<15>1 2021-11-08T19:49:55Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="901"] Portal: Token expiry timer will trigger in 18.3075 minutes
<15>1 2021-11-08T19:49:55Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="reset" filename="Portal.qml" line="919"] Portal: Reset token expiry timer: lun nov. 8 14:09:13 2021 GMT-0600 minutes: 18.3075
<12>1 2021-11-08T19:49:58Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default"] stale focus object QQuickTextInput(0x28100def0) , doing manual update
<12>1 2021-11-08T19:49:58Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default" filename="XFormBarcodeScanView.qml" line="425"] qrc:/qml/XForms/XFormBarcodeScanView.qml:425:9: QML XFormText: Cannot anchor to an item that isn't a parent or sibling.
<12>1 2021-11-08T19:49:58Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default" filename="XFormBarcodeScanView.qml" line="425"] qrc:/qml/XForms/XFormBarcodeScanView.qml:425:9: QML XFormText: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
<12>1 2021-11-08T19:50:00Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default"] stale focus object TextBoxButton_QMLTYPE_127(0x2810ba5d0) , doing manual update
<12>1 2021-11-08T19:50:00Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default"] stale focus object StyledImageButton_QMLTYPE_34(0x2810e44d0) , doing manual update
<12>1 2021-11-08T19:50:01Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="default"] stale focus object StackView_QMLTYPE_312_QML_1231(0x281050fd0) , doing manual update
<15>1 2021-11-08T19:50:14Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 2
<15>1 2021-11-08T19:50:15Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 0
<15>1 2021-11-08T19:50:42Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 2
<15>1 2021-11-08T19:50:42Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 4
<15>1 2021-11-08T19:50:42Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="903"] Portal: Token expiry timer disabled
<15>1 2021-11-08T19:50:42Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="901"] Portal: Token expiry timer will trigger in 17.5189 minutes
<15>1 2021-11-08T19:50:42Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="reset" filename="Portal.qml" line="919"] Portal: Reset token expiry timer: lun nov. 8 14:09:13 2021 GMT-0600 minutes: 17.518866666666668
<15>1 2021-11-08T19:50:48Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 2
<15>1 2021-11-08T19:50:50Z Diego ArcGISSurvey123 16492 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="404"] Portal: Application state changed: 0
by Anonymous User
Not applicable
Thanks for answering those questions. From the logs I don't see anything related to submission errors. From your explanation it sounds as if during the submissions, the network drops out, meaning some or all of the data has been sent for that survey, but the app has not recieved a reply to say it was successful, meaning it gets moved to Sent box. This would eventually cuase an error (timeout) and if you submit again, may cause a duplicate record, as a new globalid would be created. I assume the duplicate you see have different globalids?
The best way to ensure this does not happen, is always save surveys to the Outbox in areas of poor network connection, and only send them when the connection is solid and surveys can be sent without interuption. This is important when you have a lot of images or large attachments in your surveys, as they add to the time it takes to successfully send a survey.
Regards,
Phil.
Hi Phil,
Efectily , the duplicate register has a diferent global ID.
I share the screenshot
I compared the data and attachments of both records and they are identical but with different Global ID and therefore all the data was sent but the application not having confirmation issued the sending error as you had informed me.
In my opinion in these cases, it would be great if the application could double-check that all the data was sent before sending an error message on sending
Regards,
