Strange Error Message
939
04-25-2022 11:49 AM
LydiaWerner_MAC
Phoning a friend for a very strange error message I am getting on a survey I created. I have a Creator level license. Hoping the brain trust has some ideas!
Katie_Clark
So, uhhh....I've never had an error quite like that before but I'll try to help (unless someone else more knowledgeable jumps in!)
So, looks like you're creating this survey in the web version rather than Connect, correct?
This is just a wild guess, but I wonder if that apostrophe in Allen's Hummingbird is causing an issue? That's an option from a select_one or select_multiple question, correct?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
I also found these articles that reference the same "FormLogicError" message....perhaps there's something in them that could help?
https://community.esri.com/t5/arcgis-survey123-questions/formlogicerror-could-not-evaluate-model-ins...
https://community.esri.com/t5/arcgis-survey123-questions/formlogicerror-in-survey123-webapp-with-rel...
Best,
Katie
LydiaWerner_MAC
@Katie_Clark I have gotten this message intermittently between late last week and today. I created the survey in Connect, but was testing it out in a web browser. This is a select_one question as well. I have a separate CSV for this specific question (and another as well). I've attached my survey form and choices list.
