Sting-Length...>0 formula not working
2219
8
06-07-2017 11:27 AM
CarlHolt1
Since the v2.x update the string-length(${SPEC_COND_1})>0 formula has not been working. When viewed on the form it appears a space is being added. If a user clicks inside the text field and backspaces, the dependent question is hidden.
Example:
string-length(${SPEC_COND_1})>0 formula in the relevant field:
JamesTedrick
Esri Esteemed Contributor
Thanks Carl,
It looks like there's a space in the original data table you're generating the URL from.  A workaround would be to add an "and ${question} != ' '" to the relevant questions.
JamesTedrick
Hi Carl,
I'm not able to replicate this behavior in Windows or other devices.  Perhaps you could check to see if a space got into the default column of the XLS file?
CarlHolt1
No, there is no space in the default column. The behavior appears to be happening when the form is opened from the custom URL link.
This form is being opened from a custom URL from Collector, there is a layer in Collector that has information in these fields, if there is data then the relevant-dependent fields are visible and the users must answer the questions.
Custom URL:
arcgis-survey123://?itemid=102b96d8619f4f58a6a71ec6974a596a&field:GRNWY_NAME={PROPERTY_N}&field:WATERSHED={CREEK_NAME}&field:GW_ID={GREENWAY_I}&field:GRNWY_TYPE={Fee_CE_Acq}&field:NOTES={NOTES}&field:SPEC_COND_1={SPEC_CON1}&field:SPEC_COND_2={SPEC_CON2}&field:SPEC_COND_3={SPEC_CON3}
JamesTedrick
Hi Carl, thanks for the added detail.
I'm still not able to reproduce this.  Can I ask you to open the Collector map up in the ArcGIS Online Map Viewer, click on one of the features that generates the issue, and copy the link in the popup and then paste that in a text editor?  This should look much like the link above, with values filled in.  In particular, you should see if the value that is giving a space does so in the link (either a space or a %20 in the URL).
CarlHolt1
Yes a %20 does show up.
arcgis-survey123://?itemid=102b96d8619f4f58a6a71ec6974a596a&field:GRNWY_NAME=HAMPTON&field:WATERSHED=Utoy%20North%20Fork&field:GW_ID=UNF11&field:GRNWY_TYPE=Fee&field:NOTES=%20&field:SPEC_COND_1=%20&field:SPEC_COND_2=%20&field:SPEC_COND_3=%20
JamesTedrick
Thanks Carl,
CarlHolt1
Would the changes to the relevant field overwrite the existing data on the form?
JamesTedrick
No, a change of relevant formula does not cause the existing data to be overwritten
CarlHolt1
I removed the spaces from the fields using the feature service layer in AGOL.
