Start up crash in VM
2731
8
03-30-2017 05:51 PM
AngusHooper
Survey123 & Operations Dashboard are crashing on start up in a windows 2012 R2 VM.
The only other discussion I could find was this problem, but the resolution did not solve our issue.
  Problem Event Name:                     APPCRASH
  Application Name:                           Survey123ConnectforArcGIS.exe
  Application Version:                         1.10.43.0
  Application Timestamp:                  584e48c4
  Fault Module Name:                        AppStudio-WindowsLocation.dll
  Fault Module Version:                     0.0.0.0
  Fault Module Timestamp:              5824ee82
  Exception Code:                               c0000005
A colleague span up a similar VM and had Survey123 crash with OpsDashboard working.
My next thoughts are to test if it is a VC redistributable problem.
JamesTedrick
Esri Esteemed Contributor
Hi Angus,
Thanks for replying.  It looks like it may be an issue with AppStudio, which is used to build Survey123.  NManocha-esristaffanshuman_mathur‌ - can you take a look at this?
AngusHooper
Cheers.
I am assuming it is due to 2012 R2, however there is inconsistency with the crash across several VM's at R2.
ErnestoCarreras4
I am encountering the same issue - Windows Server 2012 R2 Standard
Problem signature:
Application Version: 2.0.41.0
Application Timestamp: 5907fa4f
Fault Module Timestamp: 58ac6785
Exception Offset: 00001f81
OS Version: 6.3.9600.2.0.0.272.7
Locale ID: 1033
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 6ee2
Additional Information 4: 6ee2432e64e99bdcea5e4be767a3b1a2
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
GISSupport3
I am also having this issue on a Windows Server 2012 R2 machine with the latest 2.4 release.
ShobanaSuresh
Can you try deleting AppStudio-WindowsLocation.dll and AppStudio-WindowsLocation7.dll files from \Users\Username\Applications\ArcGIS\Survey123ConnectforArcGIS\position and then launch Connect again?
Thanks
Shobana
AngusHooper
We ended up changing the OS to workaround this problem.
The behavior was logged with Esri technical support and they replicated the issue.
As we no longer had the environment nor a requirement to stay within 2012 R2, the ticket was closed and testing continued internally at Esri.
If you wish to pursue this further, the case # was 01911169.
Cheers,
Angus
GISSupport3
Yes!  Well the 'front page' screen now opens.
Thanks
GISSupport3
When I click close I now get ..
Problem signature:
Application Version: 2.4.60.0
Application Timestamp: 59b20f61
Fault Module Name: StackHash_6c65
Fault Module Version: 6.3.9600.18790
Fault Module Timestamp: 598d1b42
Exception Code: c0000374
Exception Offset: PCH_8E_FROM_ntdll+0x0003C8AC
OS Version: 6.3.9600.2.0.0.400.8
Locale ID: 3081
Additional Information 1: 6c65
Additional Information 2: 6c65dfe5c99cae373ec67095356a1dc4
Additional Information 3: e260
Additional Information 4: e260d60394c2cc6dac165fec25710c77
I can run from another machine for now.
Thanks
