Configured the detailed map settings; Home Location and Zoom Level.
But when I view the Site Map for Individual results in Suvery123 for ArcGIS website it zooms on San Francisco
Hi Carl,
Thanks for your detailed feedback.
After creating a simple survey that uses the same default home location as in your screenshot, I can reproduce the "San Fransisco" issue. However, can you please confirm it's the same issue you've seen as below?
That is correct.
Hi Carl,
This is a known issue with eh Survey123 website; we've been made more aware of it through the use of the custom print templates. We'll be working to address this issue.
Carl,
Thanks for the confirmation, the issue has been addressed and will be fixed in 2.4 release.
