Signatures from the app are not recording
609
11-01-2024 12:27 PM
rregpb
Signatures from surveys filled in the Survey 123 app are not recorded since the beginning of October. We can sign on the app, but we can't retrieve the signatures when we generate reports or look at the entries. Is it a new bug or is there a way to adjust settings to make it work?
Tags (3)
abureaux
MVP Frequent Contributor
Not that I am aware of. Sigs working my apps last I checked.
MoyerSolutions
I am having this same issue.
JesseCloutier
Esri Community Manager
Hi @rregpb and @MoyerSolutions, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
